Activity Forums Adobe After Effects How to get this “old time” visual effect?
  • How to get this “old time” visual effect?
    Posted by Rudy Shalamar on August 24, 2009 at 2:54 pm
    I have imported some image sequences for which i would like to make look like this old baseball card…
    https://www.freewebs.com/aerograd/1965_Topps_Mickey_Mantle_2.jpg
    I know I could probably do it in photoshop but since it would be easier to import the sequences straight into AE it would be much easier if there was a way to effect the images in AE itself.
    Any ideas?
    Thank you!
    Larry S. evans ii replied 17 years ago 5 Members · 4 Replies
  • Chris Buttacoli
    August 24, 2009 at 3:39 pm
    I would say make the card in photoshop, with an alpha channel cutting out the Mick for compositing, and import that into AE along with your image sequences.
  • Chris Wright
    August 24, 2009 at 8:17 pm
    If you want a quick way to do it in AE, it comes with a decent preset called presets -image creative – colorize – sepia. Put that in an ajustment layer and fiddle with the opacity. Also, file-project settings, “blend colors using 1.0 gamma” can blend the colors in yet another pleasing way. Add a hue/sat to your footage to rotate the hues can create offset colors similar to faded in conjunction with contrast tweaking. Finish with noise/grain
    https://technicolorsoftware.hostzi.com/
  • Scott Novasic
    August 26, 2009 at 5:13 am
    digieeffects film damage plugin does a great job of ‘olding’ up footage…
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Larry S. evans ii
    August 26, 2009 at 5:11 pm
    All good ideas for making “old film”, but i think what you are looking for is the halftone moire pattern that comes from the low-resolution dot prints used for those old cards.
    Personally I would use the CC Ball Action Effect (included in CS3/CS4 not sure about earlier versions) with a grid spacing of something like 1 or 2 and a scatter setting of 0.1, You can adjust the ball size up or down but I wouldn’t go over something like 60 or so. At 60 and below you can get what appears to be a halftone look. Above 60 it starts looking like square pixels (which is one way to get a pixelated effect) as the edges of the balls go outside the gridspace.
    Larry S. Evans II
    Executive Producer
    Digital I Productions
