Activity Forums Adobe After Effects Expressions how to get the opposite?
  • how to get the opposite?
    Posted by Marten Kopp on March 25, 2009 at 2:59 pm
    I got a question. Propeply very simple but I just dont understand a thing. How do you get some layer property to get the opposite value of another? e.g:
    the scale of my solid is 100% and the 2nd solid is -100%. how do I get the scale of my 1st solid to get to -100% if I keyframe the other to 100%??
    Sounds easy. Sorry for my poor english but I hope you guys understand my question.
    cheers.
    Pedro De jesus replied 10 years, 3 months ago 4 Members · 12 Replies
  • 12 Replies
  • Dan Ebberts
    March 25, 2009 at 4:07 pm
    Just apply a Scale expression like this to the 2nd solid:
    -thisComp.layer(“1st solid name”).transform.scale
    Dan
  • Marten Kopp
    March 25, 2009 at 4:57 pm
    Thnx for your reply. But that wasnt exactly what i ment.
    What I’d like to know is this:
    What expression is needed to let one layer shrink the size the other layer grow?
  • Dan Ebberts
    March 25, 2009 at 5:06 pm
    More like this then, maybe:
    s = thisComp.layer(“1st solid name”).transform.scale;
    [100-s[0],100-s[1]]
    Dan
  • Marten Kopp
    March 25, 2009 at 5:33 pm
    Hi dan,
    Thnx for the help. But it still doesnt do what Im looking for. Solid 2 scale’s along with Solid 1 but it needs to go the oposit direction, like this:
    s1 = 100
    s2 = 100
    s1 = 150
    s2 = 50
    s1 = 200
    s2 = 0
    etc..
  • Dan Ebberts
    March 25, 2009 at 5:42 pm
    Try this:
    s = 200 – thisComp.layer(“1st solid”).transform.scale[0];
    [s,s]
    Dan
  • Marten Kopp
    March 25, 2009 at 7:47 pm
    Thnx man. That worked out great!
  • Gustavo Saliola
    December 27, 2012 at 4:28 pm
    Hi Dan, i’m just looking for something similar, but in this case, with “y” position, to animate two eye lids in a bug, in opposite positions with an Expression Control.
    Thanks in advance.
    Gustavo.
  • Dan Ebberts
    December 27, 2012 at 4:56 pm
    Assuming you have a Slider Control on a layer named “controls”, it would look like this for the upper eyelid:
    s = thisComp.layer(“controls”).effect(“Slider Control”)(“Slider”);
    value – [0,s]
    and this for the lower:
    value + [0,s]
    Dan
  • Gustavo Saliola
    December 27, 2012 at 5:33 pm
    Thanks Dan! You Math Monster!
  • Pedro De jesus
    June 7, 2016 at 8:47 pm
    Hey Dan,
    Is there a command name we can use in expressions to tell it to do the opposite of what the original layer its pick-whipped to? Meaning, if LAYER 1 is moving up, and I want LAYER 2 to do the direct opposite (go down at the same speed while being connected to LAYER 1 via an expression), what command name should I use for that?
    This is just one example, but essentially I’m looking to be able to apply the opposite/inverse expression command to many other situations. Thanks!
