Activity › Forums › Adobe Photoshop › How to get smooth strokes when drawing with brush?
Posted by Pavan Ganti on March 16, 2014 at 11:31 amHi,
I’m quite new to photoshop and have been experimenting trying to draw figures with the brush tool and a tablet.Is there a function in photoshop that smooths out the stroke you draw so that I can get clean lines similar to that of illustrator?
PavanAnastasia Antonova replied 10 years, 10 months ago 6 Members · 5 Replies -
Jeff Hinkle
May 5, 2014 at 2:14 pmI guess that depends on exactly what you’re expecting by “clean.” How are your strokes not-clean? Most of the brush presets in Photoshop should give you decently smooth lines with no tweaking. Can you post a screen shot of the result you’re getting that you’re not happy with?
It is easier to destroy than to create.
More fun, too. -
Cora Smith
August 3, 2015 at 5:37 pmWhat does exactly a clean stroke means in photoshop language guys?
Aron Sherman
August 5, 2015 at 1:05 amI might be getting this same problem. Basically, when drawing with my Wacom tablet, All of my lines look jagged, as if they were just a bunch of straight lines connected together. What should I do?
Herbert Van der wegen
August 13, 2015 at 9:00 amTry a different (older) Wacom driver.
https://www.youtube.com/watch?v=va5SLNOHEF4
Also, Laxy Nezumi can be very helpful. Unfortunately, Photoshop does not offer any built-in smooth stroke control. Even when you do fix the jagged lines issue, when drawing zoomed out on a large high-resolution canvas, Photoshop still has issues with ugly lines.
I have left Photoshop for drawing altogether since more than two years now, and I prefer Krita for digital drawing and painting now (which happens to be free and open source!). https://krita.org/ Give it a chance – you may never want to draw and paint in Photoshop ever again.
I also use Clipstudio, of which the drawing feel is far superior to Photoshop.
System: Win7 64bit – i7 920@3.6Ghz, p6t Deluxe v1, 48gb (6x8gb RipjawsX), ATI 7970 3gb, EVGA 590 3GB, Revodrive X2 240gb, e-mu 1820. Screens: 2 x Samsung s27a850ds 2560×1440, HP 1920×1200 in portrait mode -
Anastasia Antonova
October 27, 2015 at 6:07 pmuse the pen tool and create a path (putting down points). if you press on a new point, hold, drag your mouse, itll make the line curvy and smoth. once your done, right click on your path and select stroke path and itll stroke the path with the current settings of your brush.
xx
stas
