Activity Forums Adobe After Effects Expressions How to get shape path vertices with script?
  • How to get shape path vertices with script?
    Posted by Joshua Faget on October 16, 2016 at 1:03 pm
    Hello,
    What I am trying to do is get all the vertices points from a selected path. Is this possible?
    I tried doing as described on page 177 of CS6 scripting guide, but I am getting a undefined result.
    var selectedShape = app.project.activeItem.selectedProperties[0].value.vertices ;
    alert(selectedShape);
    Xavier Gomez replied 9 years, 11 months ago 2 Members · 3 Replies
  • Xavier Gomez
    October 16, 2016 at 3:54 pm
    What property are you selecting ? Normally your code line should work if you select a mask path property or a shape path property.
    It won’t work for special shapes like Ellipse/Rectangle/Star (you’d need to convert them to a path before).
    Xavier
  • Joshua Faget
    October 16, 2016 at 5:11 pm
    I was selecting the proper thing, adding a .path fixed it!
    var selectedShape = app.project.activeItem.selectedProperties[0].path.value.vertices;
  • Xavier Gomez
    October 16, 2016 at 6:00 pm
    Ah ok…
    if you select a mask path (keyframable), the mask group (renamable) is selected along, and selectedProperties[0] is the mask group, not the mask path.
    Same for paths inside vector layers.
