Activity › Forums › Adobe Audition › how to get rid of someone clearing their throat from audio
Posted by Shawn Thomas on September 19, 2015 at 4:23 amSo I have an audio track for a podcast where someone is talking and nother person clears his throat loudly. He does this a few times, can I get rid of this?
Simon Billington replied 10 years, 11 months ago 3 Members · 2 Replies -
Joseph W. bourke
September 19, 2015 at 5:12 pmHow successfully you can do this depends on whether the throat clearing is stepping on the other person’s audio, and whether there’s an example of the throat clearing which is clean, with no other audio going on. If you can get a clean sample of the throat clearing, you may be able to do a sample, and then remove the sampled audio from the rest of the clip (if the clearing is pretty identical across the board. At any rate, this link will get you all you need to know to remove the noise, whether or not you can get a clean sample:
https://helpx.adobe.com/audition/using/noise-reduction-restoration-effects.html
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Simon Billington
September 24, 2015 at 1:27 pmIf the through the clearing is in between useful audio, you can usually cut out the offensive audio or use level key framing to drop the volume in the appropriate place.
Trouble is that can leave dead space within the audio, so you may need some “room tone” to place in the gap to eliminate that sudden drop out.
If the offending noises are underneath your dialogue or useful audio, it gets a lot trickier to remove. It’s possible to achieve a decent job in Auditiion, but for more tricky stuff requires something a bit more advanced like iZotope RX Audio Editor.
