how to get quicktime plugin to render quicktime
Bryan Wells replied 16 years ago 5 Members · 19 Replies
Mike Kujbida
August 28, 2010 at 12:02 pmIn the online Help menu, go down to “about Vegas Pro”.
The version number will be listed in there. -
Russ Hurley
August 28, 2010 at 12:23 pmok will do – just waiting for A DVD to render (yawn…)
Sony Vegas London Users Group
Russ Hurley
August 28, 2010 at 12:34 pmits build 896. i just got it to render A MOV! But it reads mp4s (if the apple quicktime is uninstalled, it asks for it) as just audio. So to summerize…
* without QT insstalled – no dice.
* with QT, i get audio only.
Mike Kujbida
August 28, 2010 at 12:57 pmNot the build number, the version number.
With that build number though, my guess is that you don’t have the latest version so I highly recommend doing that for the reasons stated earlier.
Vegas Pro updates -
Russ Hurley
August 28, 2010 at 1:20 pmyeah its straight 9.0. thanks for the link. i’m hesitant to upgrade when in the middle of a tight deadline vproject – been caught out like that before – but thanks!
Mike Kujbida
August 28, 2010 at 1:22 pmHere’s a list of QuickTime bug fixes in Pro 9.
You see why it’s important to keep your software up to date.9.0b:
Fixed a bug that prevented some QuickTime files from reading audio properly.9.0c:
Fixed a crash when displaying the Audio tab for QuickTime templates when using QuickTime 7.6.4.
Fixed an issue reading QuickTime audio when using QuickTime 7.6.4.9.0d:
Corrected a problem that could cause black frames in MOV files after installing the QuickTime 7.6.6 update.
Fixed a problem that could cause corrupt video when rendering to QuickTime format using the 3 Mbps Video template. -
Mike Kujbida
August 28, 2010 at 1:24 pmi’m hesitant to upgrade when in the middle of a tight deadline vproject
Smart man!!
Never ever upgrade in the middle of a project.
Wait until it’s all done and then do the update. -
Russ Hurley
August 28, 2010 at 1:30 pm🙂
Thanks Mike. Hope i can retern a favour to you sometime.When i have time.Sony Vegas London Users Group
Bryan Wells
August 28, 2010 at 2:03 pmI am using Vegas 9.0e, yet I still have problems with MOV files. So far, I have used QT Pro and rendered (pass-through) to mp4, and it works after that.
Can you clarify for me the order I need to install? Is all MOV support supposed to be in the Vegas 9.0 installer? I installed QT Pro before installing Vegas, but I just want to see if I might be missing something with my installation to help straighten this out.
Bryan Wells
