Activity › Forums › Adobe Illustrator › how to get PS bevel / emboss type effects in illustrator?
Posted by Patrick Collins on October 22, 2010 at 8:13 pmHi everyone,
So, I have a graphic that I’ve made in photoshop and I am deciding that it makes more sense to have it as vector art– And I am not sure how to get my text to look how I have it in photoshop. I was using the layer style bevel emboss, but I don’t see anything comparable to that in illustrator… So I am wondering in Illustrator, how would I go about giving text some highlights similar to this?
https://collinatorstudios.com/www/foobar.png
Thanks.
-patrick
Max Tovar replied 8 years, 7 months ago 5 Members · 9 Replies -
Mike Gondek
October 22, 2010 at 8:59 pmeffect >> 3D >> Extrude & Bevel
position: front
bevel: rounded
extrusion depth: varies: try 4
bevel depth: varies: try 2ENJOY!
Patrick Collins
October 23, 2010 at 3:21 amHmmm… I am not feeling like I have the kind of “control” that I am looking for… In photoshop I can easily edit the layer style and tweak and tweak and tweak, where this feels much more permanent and much more difficult to change later… How is something like this normally done? Do artists usually just use something like the pen tool and create lighting shades that way?
-patrick
Patrick Collins
October 25, 2010 at 7:36 pmOk, I went and bought path styler pro…
Now I am confused why I can’t get anything to look good.. Everything that path styler pro does ends up looking like pixelated trash in AI…
Plain text:
https://collinatorstudios.com/www/path_styler_1.pngPath styler pro settings:
https://collinatorstudios.com/www/path_styler_2.pngI click ok, and pixelated trash:
https://collinatorstudios.com/www/path_styler_3.pngWhat am I doing wrong???
-patrick
Vincent Rosati
October 25, 2010 at 7:58 pmI’m not totally sure about that plugin, but I’d try doing an export and see what it looks like. In Illustrator, it’s not so much what you see in the artboard that counts, but what prints or exports.
When I initially saw your post I started putting together a file. I trashed it when I saw the responses. Anyway, what I was going to offer was doing an Offset Path.
Set your type (make it kinda big).
Create outlines.
Then Object/Path/Offset Path. Use a negative value like 2pt or whatever. You can enable Preview while in this dialogue box. This will create the interior structure of the bevel.
Now you will have all of the points and paths you will need to draw the bevel effect.Total control, and it will look as good as what you put into it.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Mike Gondek
October 25, 2010 at 8:27 pmNever tried pathstyler, and their newest plug-in tryout did not work with my CS4.
You can try changing your Effects >> Document Raster Effects Setting to 300dpi.
Mike Gondek
October 25, 2010 at 8:45 pm -
Les Nemeth
October 26, 2010 at 2:51 amPathStyler Pro uses the same editable raster effects as AI. With “same” I mean, one raster effect looks just as good at 300dpi as another.
The only difference might be if you are using an effect that utilizes an image texture. In that case you need to make sure that you are using a high quality texture (like 300dpi) if you want to make it look god when printed.
