Activity › Forums › Maxon Cinema 4D › how to get out of customization window in C4D
  • Jim Scott
    September 22, 2016 at 5:44 am
    Very interesting. I have never seen that before. In Window > Customization, all I see is Customize Commands, Menus, and Palettes. How did you get to the Customization window in the first place? I would think that quitting and restarting C4D would get you back to your Startup (User) layout.
    Good luck.
  • Prem Kumar
    September 22, 2016 at 5:57 am
    Tried that several times. It did not work. Though I am getting Menu bar in other layouts like Tracking, Sculpting etc but has the problem with the standard and startup layout. I just went to customize layout (user layout) and got stuck in that only… Tried loading layout also but in vain.
  • Jim Scott
    September 22, 2016 at 3:42 pm
    You could try trashing (or temporarily removing) the C4D preferences folder. To find it go to Edit > Preferences (or CMD + E) and click on “Open Preferences Folder” at the bottom of the window. Also trash your new.c4d file in the Cinema 4D RXX application folder. This should reset everything to factory defaults. Or reinstall C4D. Or give Maxon support a call, which may be the wisest and easiest.
    Best of luck.
  • Prem Kumar
    September 23, 2016 at 5:31 am
    Thank you, I will give it a try…
  • Damiyo Sibande
    January 4, 2025 at 2:48 pm
    Hey prem lol i also found myself in the same situation. I came here for a solution but didn’t find any useful suggestion.. so i started tnkering around and figured out the issue..
    See when you pressed
    Windows> customisation> menus> User menue 1
    While in startup mode. You basically set the startup mode/layer to be treated as ‘User menue 1’ . Somthing like a reroute or redirect.. so every time you press on the startup it will show you the menues that are in ‘User menue 1’.
    The issue is that the layouts from ‘User menue 1’ until ‘user menue 5’ dont have the . ‘Windows ‘ bar to allow you to reverse what you did in the first place. Atleast not easily.
    The solution.
    Go to >customization >customize menus
    And there in the bar you should see ‘M_EDITOR_USER1’ or whichever ‘user menu no’ you rerouted your startup to.. mine was ‘M_EDITOR_USER2’ since i accidentally rerouted mine to ‘user menue 2’
    Anyways … under that menue you’ll see 2 submenus.. which is ‘submenu File’ and ‘submenus customisation ‘..
    Just switch to a different M_editer menu which has alot of submenues. Like ‘M_EDITOR’ or ‘M_EDITOR_BP’..
    Yo dont really need all of them. U just need the ‘Windows ‘ submenu. So just click on windows. At the bottom where the ‘details’ panel is youl see the options to copy.. click copy.
    Go back to ur ‘M_EDITOR_USER1’ menue. Or whichever no. U rerouted to. Clich on any of the 2 submenus to make the ‘details’ panel to light up… click on paste. Than ‘apply’ and than ‘save all changes ‘..
    Go back and you should see an editional ‘Window’ bar in your top menus.
    Now press window >customization>menus> Cinema 4d menu
    To reroute it back to how it used to be..
    It should work just fine now,👌🏻✨
