Activity Forums Apple Final Cut Pro How To Get in Sync Audio from FCPX into FCP7
  • How To Get in Sync Audio from FCPX into FCP7
    Posted by Marcus Hardy on March 2, 2013 at 4:30 am
    Hello all!
    I’m having a problem with ol’ FCP7, or rather how x-7 translates my fcpx timeline into a fcp7 one. Whenever I export an xml and translate it, when I bring it into FCP7 the edit placements are in tact but the audio has slipped to the beginning of the take. I’m not sure what to make of this, anyone have any suggestions on how I can avoid this? The projects audio is ultimately going to logic, hence the long winded approach.
    Andy Mees replied 13 years, 6 months ago 2 Members · 1 Reply
  • Andy Mees
    March 2, 2013 at 7:00 am
    Hey Marcus
    If you’ve found a case which Xto7 isn’t handling well then I suspect the developers will want to have a look.
    From their website:
    Please use Provide Feedback… under the application menu for bug reports, feature requests or support. If you need to email an XML file, please zip the file and send it to Xto7@AssistedEditing.com with a brief description of what happened.
    Cheers
    Andy
