Activity › Forums › Maxon Cinema 4D › How to get grid on objects in c4d?
Posted by Kenneth Knudsen on April 5, 2016 at 1:21 pmHow do i get grid on objects that i make in c4d? Ty for help.
Kenneth Knudsen replied 10 years, 4 months ago 2 Members · 5 Replies -
Jim Scott
April 5, 2016 at 3:57 pmIf you just want to render the grid of polygons that make up your objects the quickest way is to use the Standard renderer and add the Cel Renderer effect. In the effects “Basic Properties” select Edges and choose the Edge and Background colors.
Here’s an example:
If you want to render a full wireframe image, check out this tutorial:
https://lesterbanks.com/2014/11/3-quick-methods-rendering-wireframe-c4d/
Remember… Google is your friend.
Jim Scott
April 5, 2016 at 4:06 pmIf you just want to see the polygons that make up your objects while you are modeling, select one of the options under the Display menu in the View window that include “Lines.”
If you want something else, please provide a more descriptive question or an example image.
Kenneth Knudsen
April 6, 2016 at 10:16 pmnot sure if i did understand what u said. What i want is, when you see this guy put in an object, all objects got lines on them. if you know what i mean
https://www.youtube.com/watch?v=MhhWoDIbQ2M&nohtml5=False
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jim Scott
April 6, 2016 at 10:28 pmThat was answer number two above. Choose the display options you would like in the Display menu of the View window.
