Activity › Forums › Adobe After Effects Expressions › How to get decimal number to show after a basic math expression?
  • How to get decimal number to show after a basic math expression?
    Posted by Maeve Tan on February 22, 2022 at 10:01 am
    Hi all, I’m working on an AE project where there’s basic math happening, but the math answer is not exactly showing what I want.
    I have 2 var where the value will be inputted and then I have my end result var and I would want the end result to show a dot/comma and the rest after that. e.g 650.000 – 490.000 = 160.000, but at the moment it just shows 160 instead. I would like it that it show the .000 after 160.
    My expression is:
    let current = comp("xComp").layerByComment("current_value").text.sourceText.valueAtTime(0);
    let start = comp("xComp").layerByComment("start_value").text.sourceText.valueAtTime(0);
    paidOff = startValue - currentValue;
    Thanks beforehand!
    Maeve Tan replied 4 years, 7 months ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    February 22, 2022 at 11:22 am
    You can do it by adding toFixed(X) where X is number of decimal places.
    However, I assume you are working with thousands, and you need separator instead ofa decimal.
  • Maeve Tan
    February 22, 2022 at 1:28 pm
    Thanks for your reply! This seems to indeed work.
    If I would use a separator, how should I do this? The amounts are supposed to be the amount of money.
