Activity › Forums › Adobe Premiere Pro › How to get “Broadcast Quality” footage from DVCam Tape
  • How to get “Broadcast Quality” footage from DVCam Tape
    Posted by Clint Milner on June 13, 2008 at 2:52 pm
    I’m using the Adobe CS3 Suite (Premiere, Encore, After Effects, Photoshop) to author a DVD for a client.
    I’m having trouble maintaining the broadcast quality of the video.
    -I’m capturing PAL 16:9 footage from MiniDVCam tapes and editing to length.
    -I’m exporting as a movie and choosing Quicktime under the General Section
    -My compressor is DV – PAL under the Video Section, 100% Quality, no Recompression
    Taking that uncompressed Quicktime into a new (default) Compositition in After Effects. In the Render Queue,
    -Output Module, format is MPEG2-DVD
    In Encore, importing the two new files as a timeline and burning the disc.
    The result is a decent disc, but a bit grainy and not quite the broadcast quality the client saw at the post house that put the footage on the DVCam Tapes.
    Is there anything that anyone would do different to get that clean look to the video.
    Please post if you have a solution.
    Kind Regards,
    Clint
    Premiere:
    General
    Editing mode: DV PAL
    Timebase: 25.00 fps
    Video Settings
    Frame size: 720h 576v (1.422)
    Frame rate: 25.00 frames/second
    Pixel Aspect Ratio: D1/DV PAL Widescreen 16:9 (1.422)
    Fields: Lower Field First
    Audio Settings
    Sample rate: 48000 samples/second
    Capture Format
    DV Capture
    Video Rendering
    Maximum Bit Depth: Off
    Preview File Format: DV PAL
    Compressor: DV PAL
    Color depth: Millions of colors
    Jeff Brown replied 18 years, 3 months ago 3 Members · 3 Replies
  • Ann Bens
    June 13, 2008 at 3:00 pm
    If no FX is done in AE take the file straight form PP into Encore. Let Encore do the math and burn it to disk.
  • Clint Milner
    June 13, 2008 at 3:08 pm
    I’ll try that.
    I need to do two timelines and use a menu, so in the Export Settings I’m setting the Quality to 5 and using VBR, 2 Pass.
    Should I be doing anything different/else?
    I’ll reply with the results.
    Clint
  • Jeff Brown
    June 13, 2008 at 3:36 pm
    You didn’t mention how long the video ran, but you can go to the advanced settings and possibly max out the bitrate– at a certain point it doesn’t make much difference, but you can safely go up to 7 Mbps for video, as long as the file will fit on disc. If it is a short file (under 20 min? I haven’t done the math), you should be able to just use 7 Mbps, CBR, one pass. It won’t get much better than that.
    The big difference is you client is comparing MPEG compressed to “fresh” DV, and possibly also in 2 different viewing situations – with the post house maybe having a better monitor, proper environment lighting (one would hope), and that free cappucino and scones on the work table.
    -jeff
