Activity Forums Adobe After Effects Expressions how to get ‘actual’ width of a text layer.
  • how to get ‘actual’ width of a text layer.
    Posted by Jamie Bradshaw on February 10, 2008 at 9:01 pm
    Is there an expression that returns the actual width of a text layer?
    For example, if you have a text layer, it’l return the actual width of the text, and not the composition width.
    I’ve tried:
    n = thisLayer.width;
    but that doesn’t work.
    Many thanks,
    Jamie
    Jan Vork replied 9 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    February 10, 2008 at 9:19 pm
    You can do it with scripting, but not expressions.
    Dan
  • Jamie Bradshaw
    February 11, 2008 at 10:18 am
    Ah okay, thanks Dan.
    I haven’t had much dealing much with scripting. Would this be a difficult thing to do?
  • Dan Ebberts
    February 11, 2008 at 1:20 pm
    Not really. Here’s a simple snippet that assumes your text layer is layer 1:
    var myLayer = app.project.activeItem.layer(1);
    var r = myLayer.sourceRectAtTime(0, false);
    alert(r.top + ” ” + r.left + ” ” + r.width + ” ” + r.height);
    The top and left values are relative to the layer’s anchor point.
    Dan
  • Lloyd Alvarez
    February 11, 2008 at 2:49 pm
    Actually NAB figured out a way to get the size of a text layer in expressions using sampleImage. He posted his expression over at ae nhacers. I don’t think the cow allows posting any ae nhancers urls so just replace [dot] with a .
    www[dot]aenhancers[dot]com/viewtopic.php?f=6&t=931
  • Jamie Bradshaw
    February 11, 2008 at 2:55 pm
    Thanks Lloyd, I’ll go and check that out. I think picking up the whole concept of scripting might be a little too much for me at this moment in time.
    Jamie
  • Dan Ebberts
    Yeah, I just saw that. It should work fine. A bit slow maybe, but way better than not being able to do it at all.
    Dan
  • Jan Vork
    July 3, 2017 at 11:03 am
    Try this:
    x=thisComp.layer(“nameofthelayer”).sourceRectAtTime().width;
    x=thisComp.layer("nameofthelayer").sourceRectAtTime().width;
    http://www.jaydude.nl
