Activity › Forums › Adobe After Effects › How to get a “rock solid” track on a shaky shot??? (PART TWO)
  • Andy Kiernan
    April 7, 2024 at 5:13 pm
    Hi again Josh!
    For this kind of very specific texture, I probably wouldnt use a content aware fill type deal.
    I would track the area, make a PSR null and attach a still frame (a frame painted in PS), the mask in where needed. Then use a levels effect if there are any lighting changes.
    This will work for a camera that isnt moving too much though (as in large movements), if it is, then multiple tracks and frames will be needed I think.
  • Tom Morton
    April 9, 2024 at 6:25 am
    It might be easier to mask out the rug altogether and replace it with either a clean plate or a 3D generated alternative. If it’s not the main focus and you blended it in to a good match, it could be so subtle that no one guesses that it’s not the real deal
