Activity Forums Apple Final Cut Pro Legacy how to get a *realistic* and powerful flash effect in FCP 7?
  • how to get a *realistic* and powerful flash effect in FCP 7?
    Posted by Edwin Adkins on March 26, 2013 at 12:02 am
    In some footage I am editing, a stage performance has some performers in nearly total darkness, with occasional flashes. The problem is that although the flashes were supposed to be very powerful and have a fairly long decay, instead they turned out very mild, and too brief.
    So I need to “amp them up”… a lot. I have read many posts on using a white dip-to-color transition, and I’ve messed a lot with key-framing of the color correction levels, but neither of these work well. Especially when spread over a duration of a half- or full second, they don’t look like a flash, but instead like a white or brightness dissolve.
    Are there any other suggestions of effects (I use FCP 7)? [I see someone suggesting the “bloom” effect, which seems a bit closer. maybe I need to get the settings right…)
    edwin
    David Eaks replied 13 years, 5 months ago 7 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    March 26, 2013 at 1:20 am
    How about keying in something like this?
    https://www.pond5.com/stock-footage/8961887/paparazzi-camera-flashbulbs-flashing.html
    Shane
    Little Frog Post
  • Rafael Amador
    March 26, 2013 at 4:53 am
    [jack lee] “If you have any problem when importing Canon C300 MXF files in Final Cut Pro X/7/6, jsut follow this simple guide to transcode C300 MXF to ProRes MOV format for FCP X editing smoothly.
    Guide: How to import videos files from Canon C300 to FCP X?”
    Please, not advertising here.
    This thread is about “flash effects”; nothing related to Canon or MFX files.
    rafael
  • Joe Barta iv
    March 26, 2013 at 2:42 pm
    Check out the plugins at https://www.filmimpact.net, some are free.
    Bars & Tone
    SALUTE!
  • Anna Ingenthron
    March 26, 2013 at 9:38 pm
    The free “Too Much Too Soon” FCP 7 plug-in set has a “Flashframe” transition which is nice if set to a relatively short duration – around 8 frames or so.
  • Adam Taylor
    March 28, 2013 at 1:05 pm
    and depending upon where you intend to show the finished piece, you might come up against specific rules against using flashing images (they have been shown as a possible trigger for epileptic seizures).
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Edwin Adkins
    March 31, 2013 at 4:35 pm
    A big thanks to all of you for helping out with suggestions.
    I’ve done a draft of the footage with the flashes, and mostly used the “bloom” effect with lots of key framing, so I can get a few frames of silhouette before filling the frame with (mostly) white, then ramping down. It looks okay so far, but I also appreciate the warning about the flash impact on the viewer. They’re not repetitive enough, I think, to cause neurological issues that some strobe effects do, but it’s good to be careful.
    Edwin
  • David Eaks
    March 31, 2013 at 9:31 pm
    I read this article “Faking lighting for video with Motion 5” recently. Even though you’re using FCP7, I thought the techniques might be of interest to you.
    Found it on the FCPX Master List at fcpx.tv
