Activity Forums Zaxwerks How to get a glass look
  • How to get a glass look
    Posted by Mark Jackson on February 26, 2010 at 4:08 pm
    How do I make a material or object style look like glass?
    Thanks in advance for your help.
    Mark
    Mark D. Jackson
    Edward Wu replied 16 years, 6 months ago 2 Members · 1 Reply
  • Edward Wu
    February 26, 2010 at 8:02 pm
    Hi Mark,
    To get a glass effect, use Object Style 15. To see the swatch names, go to the “Swatch” drop down menu on the upper right corner, and enable the option “Show Names & Notes”. You can then apply Object Style 15 to your objects.
    If you’re looking to create your own glass material, the key is to make a material that has a high value set up for Highlight Sharpness and Brightness, as well as a high value set up for the Reflectivity. You will need to add a reflection map, then increase the transparency value.
    Hope this helps.
    Best,
    Edward
