Activity › Forums › Adobe Premiere Pro › How to get 1280 x 1024 Screen Capture Video on the web
  • How to get 1280 x 1024 Screen Capture Video on the web
    Posted by Nick Vitello on March 20, 2008 at 8:08 pm
    I need to take a video screen capture taken at 1280 x 1024 and posted on the web. What would be the best way. If I scale it down the quality goes way down and you can’t read any of the text, but if I leave it at it’s full size the file is too big for the web.
    Any ideas?
    Luke Goddard replied 18 years, 6 months ago 5 Members · 6 Replies
  • Jeff Brown
    March 20, 2008 at 8:54 pm
    You might want to look up “Camtasia”; it’s made for just that sort of thing.
    -jeff
  • Nick Vitello
    March 20, 2008 at 9:06 pm
    But Camtasia’s made for screen recording. What I need to do is scale down a screen recording that I already have, but keep image quality. Anyone have any tips or tricks?
  • Mike Velte
    March 21, 2008 at 11:11 am
    If you can recapture it at 800×600 as a jpeg or gif that work would best.
    OR
    If it is a .jpg or .gif, just post a link to it. Folks will need to scroll to see it all.
    https://www.video2stream.com
  • Jeff Brown
    March 21, 2008 at 2:07 pm
    Sorry, I misunderstood. You say it’s a video file, so I presume there are moving elements? That will be a tricky one. Any compression that makes it a manageable size will smear the small text, as you’ve found. If I were to advise a client on such an issue, I’d suggest re-creating the screen(s) and doing Flash animation for the moving elements. Which would require considerably more time (money). That’s my thoughts…
    -jeff
  • Paolo Ciccone
    March 21, 2008 at 4:03 pm
    Video screen grabs usually don’t have much motion so if you keep it at 15fps you should be able to reduce the files size quite a bit. Use QuickTime H.264, possibly from Compressor or other high-quality encoder, with a keyframe setting of 45, quality just above medium and it should get down to a reasonable size. How long is the video?
    Paolo Ciccone https://www.paolociccone.com
    Hellriser Digital
    Santa Cruz, CA
  • Luke Goddard
    March 22, 2008 at 1:47 pm
    You might want to try SheerVideo, for screen captures they have great compression and it’s lossless at 100% Quality so text is just as easy to read as if you were looking at the original screen.
    https://www.bitjazz.com/en/products/sheervideo/
