Activity Forums Apple Final Cut Pro Legacy How to get 1:2.35 aspect ratio. URGENT!
  • How to get 1:2.35 aspect ratio. URGENT!
    Posted by Luis Artigas on October 31, 2005 at 7:51 pm
    Greetings!
    I`ve got a friend, and he’s editing this film that was shot taking in cosideration that it would be cropped in post production to give it a 1:2.35 aspect ratio look, and to do that just by eye percentages would be very risky, I`m sure some of you have rules of thumb to do this, maybe the same rules that you apply to make 16:9 aspect ratios could work, but some guidence is urgently needed please!!
    Luis Artigas
    Union y Lucha Producciones.
    Sean Oneil replied 20 years, 10 months ago 4 Members · 3 Replies
  • Michael Buday
    October 31, 2005 at 7:59 pm
    Need some more info, like – what video or film format was the “film” acquired on? Was it shot anamorphic? What is the delivery format? Video? Film? DVD?
    All the best,
    Michael Buday
  • Alexander Serpico
    October 31, 2005 at 8:52 pm
    Its called the widescreen matte, fcp has had it since its inception….
    you can either apply it globally to your cut by applying it to a nested sequence (if your cut is done and you need to output),
    or add it to every clip prior to edit (i personally dont like this option, since i cant remove only that effect globally if necessary).
    just select type: “2.35:1” in the filters tab.
  • Sean Oneil
    November 1, 2005 at 10:31 am
    Use the filter. But if you’re just curious, 16:9 is exactly 75% the height of 4:3. 2.35:1 is in-exactly 56.755% (and change). With SD NTSC video, there are many considerations like non-square pixels, 480 vs. 486, and field dominance when cropping. FCP’s widescreen matte filter automatically takes these things into consideration for you.
    Sean
