Activity › Forums › Adobe After Effects › how to generate this static noise…
Posted by Damien Oliver on November 20, 2006 at 12:16 amIm trying to get AE7 to generate some static noise like in this clip:
cant work out a way to get the darker noise lines runing through it
any tips would be great
Damien Oliver replied 19 years, 10 months ago 6 Members · 7 Replies -
Vince Becquiot
November 20, 2006 at 1:00 amIt would be much faster to record a dirty white image to a VHS, fast forward it, and shoot it or capture it, than trying to recreate it in AE…
Vince
Damien Oliver
November 20, 2006 at 12:46 pmunfortunately it needs to be generated with an alpha mask etc to go into another comp, so will need to be manually made.
Anyone else have some tips???
Jimmy Brunger
November 20, 2006 at 2:03 pmCan’t you just capture in a fast forwarding VHS on a white fame like suggested and then in AE key out the white for your alpha key of the lines? Then you could quite easily dirty up whatever picture you want to then put the lines over in AE?
OR just play the footage you want to use onto VHS directly and then grab back in? That make any sense?!?
*Production Studio Premium / *Combustion 3
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0 -
Chris Smith
November 20, 2006 at 2:36 pmShoot a still of a white card. Use a sponge and India Ink to create the lines across the white card. Do this a handfull of times. Cycle these frames. Crush the levels in a bit and invert the image so it’s white lines across black. Then use this footage as a track matte on other video, or use transfer modes like “overlay” over other video.
Chris Smith
https://www.sugarfilmproduction.com -
Tyler Paul
November 20, 2006 at 3:13 pmI threw something together that was coming along well but I got kicked out of the edit bay.
I duplicated the lines pretty decently by generating a grid with a width thats larger than your comp and a height that leaves 4 or 5 lines across the screen. Set the border for the thickness. Rotate it slightly and then add a turbulant displace. Set the size to about 10 and an amount of about 80 and wiggle the revolution. wiggle(30,180) And I made the lines scroll down the screen.
Then in a second comp I used a grid to make scan lines. The width again is larger than your comp the height and border set to about 2.
In the final comp place your both comps. Use the scan lines as a matte.
This at the moment won’t look exactly like what you want but it’s well on it’s way.
“Life Should Come With Backround Music”
-Brown Sugar Studios- -
Ryan Hill
November 20, 2006 at 5:59 pmDraw some grey-scale gradient lines, wiggle their location, apply noise or grain, apply levels to up the contrast. Possibly apply a scatter filter in a lower-resolution composition, then scale it up and blur.
Then play with some edge filters and channel offset to make it seem a little more analog.
Damien Oliver
November 24, 2006 at 9:48 pmthanks everyone for your help, I managed to get it done mainly using fractal noise
