Activity › Forums › Adobe Premiere Pro › how to gang audio channels?
Posted by Jayson Rahmlow on August 25, 2011 at 1:58 amHi,
anyone know if I can gang audio channels together and just slide one slider up and down and have several tracks sliders mimic the slide?thx,
Jayson
https://www.woodybrando.comJonas Bendsen replied 9 years, 1 month ago 3 Members · 4 Replies -
Ben G unguren
August 25, 2011 at 3:28 amThis isn’t ganging exactly, but in Premiere you can create “submix” tracks — a feature more common in audio editing programs like ProTools. In your audio mixer you can send each audio track to the submix, and then you can use the fader on the submix to change the volume of everything passing through. You can also apply filters to submixes. For instance, when I have interviews with three people going in the same scene, I will give each person their own track so I can apply EQ and levels for that track that is specific to that voice’s needs, but then I send all three tracks into a “Voice” submix, where I will apply some dynamics (like a noise gate) as well as a little reverb to give it some room tone.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jayson Rahmlow
August 25, 2011 at 6:31 amokay cool thats good to know. but if I want to do multiple adjustments to different clips like having one section of a clip start out @ -3 db then add an edit and have it cross fade into another section of the clip at -20 db I wouldn’t be able to do that through a submix right. So is there no way to say hey these four tracks I want them all to be -20 db?
thx,
Jayson -
Jonas Bendsen
July 30, 2017 at 7:01 pmYou’d think they could have addressed this in CC, no? I just want to be able to expand/contract, apply affects, etc. mutliple “ganged” tracks without having to create a submix for each group of tracks I want to gang (which also doesn’t address expanding/contracting visuals, etc.).
This is my life, I edit and edit and edit and edit…https://TeahmBeahm.com
https://Digabyte.com
