Activity Forums Panasonic Cameras how to fix HPX 3700 stuck pixel?
  • how to fix HPX 3700 stuck pixel?
    Posted by Per Scaffidi on April 10, 2013 at 7:41 pm
    I just noticed that all of our footage shot several months ago has a single stuck pixel, not very noticeable luckily. I pulled out the camera yesterday and took a new shot. That stuck pixel is gone but in its place is another in the center of the frame. Anyone know how I can get rid of it on the 3700? I found an old varicam post saying to go into the settings and select something like “all data clear” and then black balancing, but I can’t find a setting like that in the 3700’s manual.
    David Garraway replied 11 years, 6 months ago 4 Members · 4 Replies
  • Jim Wilcox
    April 11, 2013 at 6:14 pm
    Per,
    We have a HPX2000 and had this issue a number of years ago. Don’t know if the procedure is similar, but I have a 8 page doc that walked us thru “blemish” removal for that sensor. If you have an e-mail address I can send that to you as a starting point.
  • Per Scaffidi
    April 11, 2013 at 7:05 pm
    Thanks, that seems to have done the trick!
    Just in case someone else has the same problem here’s the quick fix (there are more things to try if this doesn’t work):
    Set White Balance switch to PRST
    Set Shutter switch to OFF (on the front of the camera)
    Close Iris
    There’s a switch on the front of the camera with ABB, flick it to ABB and let it cycle til it says ABB OK.
  • Chris Tompkins
    April 12, 2013 at 1:16 am
    You should “Black Balance” every time you change recording formats.
    See pic from manual:
    Chris
  • David Garraway
    March 25, 2015 at 3:56 pm
    Jim-
    I’d like to get a copy of the blemish removal procedure for the HPX 2000. My email is David dot Garraway at msstate dot edu.
