Activity › Forums › Maxon Cinema 4D › How to fix hair redistribution when using Skin and Pose Morph at the same time ?
  • How to fix hair redistribution when using Skin and Pose Morph at the same time ?
    Posted by Nikita Ovchinnikov on October 20, 2023 at 5:07 pm
    The video shows an example of the problem
    (In the beginning both modifiers are enabled, after I turned off first skin then pose morph)
    https://vimeo.com/876459150?share=copy
    If you enable only Skin or only Pose Morph everything works correctly, how can you make them work together with hair without redistribution ?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Nikita Ovchinnikov replied 2 years, 11 months ago 1 Member · 1 Reply
  • Nikita Ovchinnikov
    November 1, 2023 at 7:47 am
    This problem is a bug of c4d 2024(2024.1.0) in version 2023 this problem does not exist
