Activity Forums Apple Final Cut Pro Legacy How to fix FCP viewer different from quicktime original footage?
  • How to fix FCP viewer different from quicktime original footage?
    Posted by Rob Lambert on November 9, 2013 at 10:05 pm
    The images in the picture are from the same source footage, top being FCP viewer and bottom being Quicktime vid clip.
    I took the clip on my desktop and opened it up, then I imported that same clip in to FCP. As you can see the FCP image is displayed much darker. Which brings up the problem of how can I make any adjustments with any certainty if the images I’m adjusting or playing with are not how they are or how they will export out to be?
    I had a friend suggest I calibrate my monitor (which I did using Sypder) – however even if I made my monitor colors green, the images displayed above would still be different shades of green. This makes it an FCP problem and not a hardware problem.
    I made the suggested adjustment in FCP settings from Accurate to Approx without much of a change.
    I look forward to reading any suggestions or workarounds as I am at a complete standstill on how to proceed with my work.
    Thanks in advance
    Rob Lambert
    Rob Lambert replied 12 years, 9 months ago 2 Members · 2 Replies
  • Don Greening
    November 10, 2013 at 4:34 am
    Confucious say “When FCP starts acting weird the first thing to do is trash the preference files.”
    There’s a free program at Digital Rebellion that will to this task for you called Preference Manager. You can find it at the link below.
    https://www.digitalrebellion.com/prefman/
    Try the program and see if this solves the colour issue.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Rob Lambert
    November 12, 2013 at 7:58 pm
    Thanks Don! I’m going to try this – does this reset the software in some way?
