Activity › Forums › Adobe After Effects › How to fix blown out lights in 3D fly-by scene?
  • How to fix blown out lights in 3D fly-by scene?
    Posted by Skylar Weeks on August 17, 2012 at 7:55 pm
    I have set up a basic 3D scene in AE that has “composition” notebooks with various school subjects falling onto an invisible plane. The camera is positioned directly above the scene and the notebooks fly-by the camera and land on the plane below. I have one spotlight positioned above the scene.
    Here is the problem: No matter what I try the spotlight is super bright when the notebooks fall just below the camera and as they fall to their final resting place the light and shadows look like I want them to. How do i avoid the problem where I have had to place my spotlight at -3400 on the Z-axis to ge it far enough away to light the whole scene, yet not overexpose the notebooks as they fall so that for a moment it looks like an all white book that then falls into a more normal looking lighting situation?
    What am I missing here? I’ve attached a screen shot to show you what is happening.
    Chris Brett replied 14 years, 1 month ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    August 17, 2012 at 8:12 pm
    One workaround would be to duplicate each layer (for the notebooks)and have the layer on the top with “accept lights” turned off- this way it’s not going to have the whites blown out by the light. Animate transparency from 100 to 0 as the notebook passes the critical point to leave the final look untouched.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Skylar Weeks
    August 17, 2012 at 8:50 pm
    I’ll give that a try. Has anyone else found a way to deal with this problem?
  • Chris Brett
    August 17, 2012 at 10:03 pm
    Hi there — I struggle with lights sometimes myself but I would try setting up separate lights for the ground plane maybe along the lines as below…
    1 ) an ‘ambient light’ to give overall level ( if required ) after local lights are set up — adjust the intensity ( or opacity ) to get the level right ( you may only need a tiddly bit extra )
    2 ) use a number of ‘spot lights’ lower down to get what you want shadow-wise etc on the books
    3 ) set up light ( s ? ) coming in from the side to catch falling books as required …
    This may not work of course but I think that it what I would try….
    —————— chris brett // uk
  • Chris Brett
    August 17, 2012 at 10:08 pm
    Teds idea sounds excellent to me as you can adjust transparency to allow as little or as much light as you want –
    – sounds a lot easier to set up as well…………
    —————————————-c–
