Activity Forums Sony Cameras How to Fix Bad Pixels on a FS-100?
  • How to Fix Bad Pixels on a FS-100?
    Posted by Thomas Hughes on October 18, 2012 at 10:44 pm
    I’ve got an FS-100 and there are two spots in the picture. They’re not the lenses so I’m thinking perhaps they’re bad pixels. With my PDW-F350 cameras, if you have a bad pixel, you black balance a few times and it fixes them. Is there a similar fix for the FS-100? Thank you.
    Thomas H
    Sherman Bahr replied 9 years ago 4 Members · 3 Replies
  • Ian Cook
    October 18, 2012 at 11:25 pm
    Same procedure but on the FS100 you access from Menu–>Camera Set–>Auto Black Balance. Do this 5-6 times after the camera has been powered on for at least an hour..
  • Sam Angello
    July 6, 2017 at 4:08 am
    Here’s a tutorial that walks you through fixing a Stuck Pixel and black balancing your camera. Hope this helps https://www.youtube.com/watch?v=EgLWw2TNhO0
  • Sherman Bahr
    July 19, 2017 at 6:47 am
    If you are referring to the Sony NEX-FS100, then hot pixels could electronically be remapped. You typically do not have to have the sensor replaced. If you would like more details on this you could give me a call.
    …Sherman 888-283-2228
    Sony And Canon Prosumer Mini DV Camcorder Repair Free Estimates. https://www.VideoOneRepair.com 888-283-2228
