Activity › Forums › Apple Final Cut Pro › How to fix Audio – MONO – Final Cut X
  • How to fix Audio – MONO – Final Cut X
    Posted by Stephan Scrofani on September 20, 2016 at 8:57 pm
    I have a filmed Skype interview, split screen style. The problem is the audio from one person is too low and audio of the other person is overblown.
    Unfortunately, I don’t have one person on each channel.
    Is there any way, other than manually key framing one person to an appropriate volume, that I can fix the discrepancy between the audio for each person?
    Thank you in advance for your help,
    Steph
    Stephan Scrofani replied 10 years ago 4 Members · 6 Replies
  • Paul Figgiani
    September 20, 2016 at 10:40 pm
    Try the Adaptive Leveler in Auphonic. (Desktop app. or the Web Service). You’ll need to process the audio outside of FCPX. Then re-import.
    https://auphonic.com
    -paul.
  • Kevin Rag
    September 20, 2016 at 11:40 pm
    Try using a compressor. It should fix the problem like this in most cases.
    Kannan Raghavan
    The Big Toad Films Pte. Ltd.
  • Joe Marler
    September 21, 2016 at 12:36 pm
    [Stephan Scrofani] “Is there any way, other than manually key framing one person to an appropriate volume”
    Here is a MacBreak Studio on using the compressor that’s built into FCPX: https://www.youtube.com/watch?v=OXxD0L9d7OU
    Everyone probably knows this but you can also drag the range select (R key = range select mode) horizontally over the clip then drag that audio range up and down and it will adjust that region, putting a head/tail transition on the adjusted range.
  • Stephan Scrofani
    September 22, 2016 at 9:05 pm
    Thank you! I’ll try this
  • Stephan Scrofani
    September 22, 2016 at 9:06 pm
    Thank you, forgot that helps
  • Stephan Scrofani
    September 22, 2016 at 9:07 pm
    Great, thanks, really helpful!
