Activity › Forums › Apple Final Cut Pro › How to Fix a Flicker/Wave Artifact (horizontal)
Posted by Ernie Munick on March 21, 2018 at 10:00 pmHard to describe. I’ve blown it way up to show the artifact in the attached video. It shows in a few spots in the vid (only one instance shown in video below), both around white matting inside a frame.
Is deflicker software the answer? Seems more an undulating effect than a flicker.
Inside light around a white matte, maybe.
Any idea?
https://drive.google.com/file/d/1bf3-9RJbtCR4z1QHzjrw3S7sGzHdZCVJ/view?usp=sharing
Bret Williams replied 8 years, 5 months ago 3 Members · 11 Replies -
Doug Metz
March 21, 2018 at 10:25 pmLooks like an interlacing artifact, based on the spacing of the ‘wave’ and angle of the shot.
Doug Metz
Anode
Ernie Munick
March 21, 2018 at 10:44 pmSpot on—I’m in a 29.97 interlace timeline (though footage is progressive).
Now, if I could fix, lessen the artifact…
Thanks, Doug
Doug Metz
March 21, 2018 at 11:12 pmEasy fix – select the project in the browser, and in the Inspector, select the Info tab. In the upper right corner, select ‘Modify Settings’. From there, you can change it from 29.97i to 29.97p
Doug Metz
Anode
Bret Williams
March 22, 2018 at 2:38 amDoes it show on your interlaced video out or are you using a computer screen? They don’t show interlaced as, well, interlaced.
_______________________________________________________________________
https://BretFX.com FCPX Plugins & Templates for Editors & Motion Graphics Artists
Hang Tag https://bretfx.com/product/hang-tag
Overshoot Text https://bretfx.com/product/overshoot-text/
Outliner https://bretfx.com/product/outliner/
Clock Maker https://bretfx.com/product/bretfx-clock-maker/ -
Ernie Munick
March 22, 2018 at 11:13 amWatching on computer screen.
And it must be the interlaced timeline: I dropped the same progressive clip in a progressive timeline—no flicker/waves.
Still wonder if there’s a fix.
Thanks, Bret
Bret Williams
March 22, 2018 at 11:24 amProgressive 30p in an interlaced timeline should look progressive. The fields can’t magically appear out of thin air. Well, they’d be there, but they’d be made from the same progressive moment in time so there wouldn’t be any visible interlacing. However, if your footage is actually 60p, then FCPX will map that to fields, which is what you want. 60p is 60 images per sec just as 29.97i is 60 images per second. It won’t look that way on TV. TV is either 720 60p or 1080i. Both are 60 images per sec. None of it looks interlaced in TV. If you’re also distributing for computers, you need to create a de-interlaced version for that.
Ernie Munick
March 22, 2018 at 11:36 amThanks, Brett. You are right.
What makes this weirder (to me), is that when I share the master file (XDCAM 35 mbps), I don’t get any of the flicker/waving. It only occurs on that timeline. In fact, when I just look at the clip in the browser…no flicker/waving.
Only in timeline (with effects on or off).
Bret Williams
March 22, 2018 at 11:55 amAnd what size is your viewer? Not 100% I’m guessing.
