Activity › Forums › Adobe After Effects Expressions › How to find the empty obj. coordinates w/ displacement and rotation animations
  • How to find the empty obj. coordinates w/ displacement and rotation animations
    Posted by Taku Wilson on July 27, 2022 at 4:16 pm
    I would like to know how to find the coordinates of an empty object parented with displacement and rotation animations in a composition.
    The small circle is the parent of the empty object. The coordinates of the empty object are relative to the coordinates of the small circle. The value remains unchanged. I want to add a write on effect, and I need to find out the coordinates of the empty object that changes during composition.
    The ultimate goal is to make a Spirograph animation, which is just one step away
    Dan Ebberts
    replied 4 years, 1 month ago
    2 Members · 4 Replies
  • Dan Ebberts
    July 27, 2022 at 4:26 pm
    When you say “empty object” are you talking about a null layer? If so, then I think you just need something like this:
    L = thisComp.layer("Null 1");
    L.toComp(L.anchorPoint)
  • Taku Wilson
    July 27, 2022 at 4:54 pm
    Thank you so much for your help, it’s amazing
  • Taku Wilson
    July 28, 2022 at 2:42 pm
    I found that this expression can also be written like this:
    var parentLayer = thisComp.layer(“smallCircle”);
    var childLayerPosition = thisComp.layer(“childNull”)(“Transform”)(“Position”);
    parentLayer.toComp(childLayerPosition)
  • Dan Ebberts
    July 28, 2022 at 3:56 pm
    Or like this:
    L = thisComp.layer("childNull");
    L.parent.toComp(L.position)
