Activity › Forums › Adobe After Effects Expressions › How to find system name of font
  • Dan Ebberts
    July 26, 2022 at 12:52 pm
    With the text tool, create a new text layer “test”.
    Add this expression to the Source Text property:
    style.font
  • Filip Vandueren
    July 26, 2022 at 4:33 pm
    You can also use the expression language menu (right next to the pickwhip, where you can find all the methods and properties) and via Text > Font… you’ll get a popup to select any font you have installed on your system complete with previews (very much like the character panel), and after selecting, the correct String with the system-name will be inserted into your expression.
  • Emre Mutlu
    July 29, 2022 at 6:20 am
    Thank you Dan and Filip.
