Activity Forums Apple Final Cut Pro Legacy How to find source clip from sub-clip?
  • How to find source clip from sub-clip?
    Posted by Ignatius Gorin on September 15, 2006 at 4:41 am
    Hi, I’m in the process of selecting clips out of 30 hours of rushes for a doc.
    I use Cmnd-U and sort “sub-clips” into separate folders.
    I’m looking for a way so in the future I can find back what source clip the sub-clip was originally taken out of, say if I need to change my in or out points later.
    TIA!
    Nick Meyers replied 20 years ago 2 Members · 1 Reply
  • Nick Meyers
    September 16, 2006 at 1:46 pm
    if you need to change in/outs,
    select the clip, go to modify menu / remove subclip limits.
    it’ll retain the name of the sub.
    OR
    option apple f will pull up the source FILE,
    and you can start all over.
    as to how you can find the original source CLIP,
    i have to admit i dont know.
    cheers,
    nick
