Activity Forums Adobe After Effects How to film for & do the invisible effect?
  • How to film for & do the invisible effect?
    Posted by Melissa Evans on September 28, 2012 at 5:38 am
    Hello,
    The effect I want to achieve is of someone turning invisible from head to toe, somewhat like the Harry Potter invisibility cloak effect. How should I go about filming for this scene, and how to create the effect in AE? I know a green screen would be the easier way, but I don’t have one. What I’m thinking of is shooting the whole scene as it is, and then shooting the exact same thing but without the invisible person, is that correct? Then in AE, use a difference matte to make the person invisible?
    Please advice on any other methods possible? Thank you!
    Melissa Evans replied 13 years, 11 months ago 3 Members · 3 Replies
  • John Cuevas
    September 28, 2012 at 12:10 pm
    From experience I can tell you that the difference mat works well in theory, but in practice not so much. Slight differences that you probably won’t see can make it extremely difficult to remove someone from a shot. Give it a shot,but test it first. And if it doesn’t work, here are a couple Cow tutorials on creating invisible man looks: The Invisible Cape
    Creating an Invisible Man
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Darby Edelen
    September 28, 2012 at 10:57 pm
    [Melissa Evans] “What I’m thinking of is shooting the whole scene as it is, and then shooting the exact same thing but without the invisible person, is that correct? Then in AE, use a difference matte to make the person invisible?”
    If your camera is locked down on a tripod then you probably won’t even need the difference matte. You can simply transition from one set of footage to another in a localized area with a mask or matte.
    You may need to color correct the shot some to match. You’ll definitely need to think through what else is visible in the shot that may move between takes (trees blowing in the wind? cars driving by?).
    You may even be able to get away with a still image from the beginning of a take (before the talent has come on screen). This would require matching the grain/noise on the video.
    Darby Edelen
  • Melissa Evans
    September 29, 2012 at 9:34 am
    Yea I think I’ll definitely try out a test shot first.. will try to minimize the other moving elements in the shot to make life easier. Thanks for the tutorials and advice!
