Activity › Forums › Maxon Cinema 4D › How to Fill Imported Path
  • How to Fill Imported Path
    Posted by Gino Terribilini on October 3, 2011 at 8:01 pm
    I’ve created my Working Paths file, open it in C4D, I have ‘Connect Spines’ ticked, I select all my paths and connect them, I create Extrude NURBS, and move my object under it and voila.. it created a 3D object. The problem here is that its creating a 3D Object of the path itself when what I want is the path to be filled (i.e. its extruding the outline rather than a solid). How do I ‘Fill’ my object or make it a solid?? Thanks!!
    Gino Terribilini replied 15 years ago 2 Members · 2 Replies
  • Tim Shetz
    October 3, 2011 at 9:14 pm
    I think what you want to do is enable caps…then you could reduce the depth of the extrude if you don’t want much thickness.
    __________
    Tim Shetz
    c4dtraining.com
  • Gino Terribilini
    October 3, 2011 at 9:23 pm
    Ah ha! Figured it out by watching the “Vector Logo to 3D Logo” on this forum. All I had to do was select ‘Extrude NURBS’ in my Objects tab, then go to the Attributes window and tick ‘Hierarchial’
