Activity › Forums › Maxon Cinema 4D › How to extrude an extruded object?
  • How to extrude an extruded object?
    Posted by Zuzanna Loch on February 2, 2019 at 8:35 pm
    Hey! First of all, I am totally new to this forum and also not a pro with C4D.
    I have the following problem: I need to create a cylinder, in which one of the bases is wavy.
    In order to achieve this, I first made a sinusoidal shape in Illustrator -> merged it into C4D -> extruded it -> put under a Boole so that it was cut into a circle.
    For now, it resembles a wavy potato chip (see the screenshot in the link). What I need is to extrude it in a way that from a thin chip, it becomes a thick wavy slice of a potato ???? Ideally, one side of that slice should be flat, instead of wavy.
    Alternatively, this could be done by cutting a cylinder with the wavy surface I have now. But all I have found was to cut the object with a straight line.
    I have been trying to achieve it for hours and didn’t succeed. However, I believe there is probably some simple way to do this, so I will be very very happy to receive any bits of advice!
    Zuzanna Loch replied 7 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    February 3, 2019 at 5:48 pm
    not enough info, here are some ways to do what I think you want… there are probably more ways
    13073_wavybottomtrial.c4d.zip
  • Zuzanna Loch
    February 3, 2019 at 10:36 pm
    Wow! Thanks man. This is exactly what I was trying to achieve. Also, I admire the clean way you structured the file, so I could follow it step by step. Thanks a lot 😀
