Activity Forums DVD Authoring How to extract AAC audio from a QT file to use in DVD
  • How to extract AAC audio from a QT file to use in DVD
    Posted by Chris Huggett on June 6, 2006 at 9:36 am
    Hey guys
    A client has given me a QT file of his corportae video. It has been compressed with the H264 codec and the AAC encoder. He wants me to extract the audio from this file and use it in a DVD.
    But im having a hell of a time trying to extract just the audio. I have QT pro, but that just crashes when i try to export out of it. Extracting the audio, only keeps it in a .mov file, which i can not use.
    I have tried a number of AAC converters off the net, but because its in AAC format, its not readable.
    CAn anybody suggest anything?
    Chris
    Dan Asselin replied 20 years, 3 months ago 4 Members · 3 Replies
  • Wts(jmanz)
    June 6, 2006 at 3:12 pm
    Have you tried Streamclip. It might ‘see’ the file and allow you to export to aiff.
    Jim
  • Nicholas White
    June 8, 2006 at 3:38 am
    Hey,
    Quick and dirty, won’t have to mess with codecs and software…
    Open an audio editor, set your soundcard to record from the ‘wave’ input (on a PC, not sure what it is on a mac), hit record, then play your quicktime file. The audio from quicktime should pass through the soundcard’s wave input and get recorded into the audio editor. Trim it, save it, and you’re ready to go onto the next step.
    Take care,
    Nick
  • Dan Asselin
    June 12, 2006 at 3:17 pm
    This may sound very Anti-Mac but here goes. If you convert the file to an AVI there are tons of free demuxers on the internet which will allow you to strip the AC3 file out. I use ReJig and it is really easy.
    Good Luck;
    Dan
