Activity Forums Avid Media Composer How to export XDCAM HD422 quicktime as “Best” quality?
  • How to export XDCAM HD422 quicktime as “Best” quality?
    Posted by Robert Combs on January 30, 2010 at 1:58 am
    I’m trying to export, from my Media Composer 4.0.5, a Quicktime move using the format Compression Type option: “XDCAM HD422 1080i60 (50 Mbs/s)”. However, for some reason, “Quality: Medium” is what shows in Export Settings window. How can I set this to be = Quality: Best?
    Rob
    John Pale replied 16 years, 7 months ago 2 Members · 4 Replies
  • John Pale
    January 31, 2010 at 4:54 am
    The data rate for that format is fixed. The quality slider has no effect, so it defaults to medium. Ignore it.
  • Robert Combs
    January 31, 2010 at 5:58 pm
    Hi John and thanks for your reply.
    Is this to say that “medium” quality is the best that I can hope for? Or, are you saying that the “medium” label is ambiguous and doesn’t really mean anything?
    I ask this because I’ve noticed a quality difference… I originally “write to device” from my Avid to a rented XDCAM HD deck and then pulled the footage from the XDCAM deck/disk to my computer’s desktop using the XDCAM Transfer software and the resulting Quicktime movie definitely looked better than when I simply exported from Avid to my desktop simply using Avid’s export command and this “medium” limited Quicktime codec.
    Now, the rental deck is gone and I want to pull a couple of revised sequences from my Avid for a new client approval DVD. I just wanted them to look as good as the other ones. What gives? Why am I just limited to “medium” and is there any way of fooling the Avid into thinking a computer folder is an XDCAM device?
    Rob
  • John Pale
    February 1, 2010 at 5:20 am
    [Robert Combs] “Is this to say that “medium” quality is the best that I can hope for? Or, are you saying that the “medium” label is ambiguous and doesn’t really mean anything?
    The medium label doesnt mean anything. XDCAM (50mbs) is always the same bit rate. It is not user adjustable. The slider is NON FUNCTIONAL in that codec. This is true for many codecs.
  • John Pale
    February 1, 2010 at 5:21 am
    “But why don’t you just make 10 louder…”
    “But this goes to 11…”
