Activity › Forums › Apple Final Cut Pro Legacy › How to export with a 2:3 cadence?
Posted by Andrew Dietz on December 2, 2009 at 7:51 pmI have a ProRes HQ file 1080PsF 23.98 that I want to downconvert to SD with a 2:3 cadence added.
My deliverable is an MXF file which I am using the Sony XDCAM transfer tool.
I am dropping the ProRes HQ file into an IMX 30 29.97 easy setup project. When I export this file, I see a 2:2:2:4 cadence added. I also tried dropping that same ProRes HQ file into an NTSC ProRes HQ project, and put it to tape, and it still output a 2:2:2:4 cadence. Finally, I did a downconversion with the Kona3 upon output, and it still output with a 2:2:2:4 cadence.
Mac OS: 10.6.2
FCP 7.0.1Matt Lyon replied 16 years, 9 months ago 4 Members · 15 Replies -
Shane Ross
December 2, 2009 at 7:55 pm[Duke Bishop] “Finally, I did a downconversion with the Kona3 upon output, and it still output with a 2:2:2:4 cadence. “
The Kona shouldn’t do this. If you use the master HD project sequence at 23.98, and use the Kona to downconvert, it will add the proper 2:3 pulldown. I have done this numerous times.
But FCP will not. FCP does the 2:2:2:4 thing…horrid. If you use Compressor to do this, then you should get the proper pulldown.
Shane
Read my blog, Little Frog in High Def -
Jeremy Garchow
December 2, 2009 at 7:59 pm[Duke Bishop] “Finally, I did a downconversion with the Kona3 upon output, and it still output with a 2:2:2:4 cadence.”
How did you do this? The Kona will output 3:2 no problems.
FCP renders in 2224 unfortunately, but compressor will add 3:2 with the proper settings.
*edit, woops sorry Shane, didn’t see you there 😉
Jeremy
Shane Ross
December 2, 2009 at 8:05 pmI’m quick. But you are ever-present!
Shane
Andrew Dietz
December 2, 2009 at 8:08 pmI’ve gotten the downconversion to work adding the proper cadence before. I think I’ll go test it on another machine.
It really doesn’t matter anyway because I am adding graphics and stuff and my deliverable is an MXF file. At this point I think my only option is to export as ProRes HQ 23.98, and run it through compressor. Then bring it back into final cut, and export using the XDCAM transfer tool.
2:2:2:4 makes me want to cry.
Jeremy Garchow
December 2, 2009 at 8:12 pm[Duke Bishop] “I’ve gotten the downconversion to work adding the proper cadence before. I think I’ll go test it on another machine.”
Not without a plug in. FCP always does 2224, unless you’re working in 720p.
Andrew Dietz
December 2, 2009 at 8:13 pm“Not without a plug in. FCP always does 2224, unless you’re working in 720p.”
I meant doing a downconversion via Kona3 card.
Jeremy Garchow
December 2, 2009 at 8:22 pm[Duke Bishop] “I meant doing a downconversion via Kona3 card.”
Got ya. Yeah, Kona card should work. There’s an option to set 3:2 pulldown style, but it’s defaulted to 3:2 (marked 2:3:2:3). It’s in the codec tab.
Jeremy
Matt Lyon
December 2, 2009 at 10:05 pmHey guys,
Thought I’d jump in here with a related question: I’m about to deliver some material in SD, uncompressed 29.97, as a quicktime file. My material is 23.98 progressive (from a film source). So I need to do a software conversion to add proper film-style pulldown. In the past I’ve done this with After Effects, since I didn’t think compressor could do proper AA/BB/BC/CD/DD style field ordering. But some of these posts seem to suggest it can? I did some quick test today with no luck. Any tips on the proper settings? I’m using compressor 3.0.5. Thanks!
Matt Lyon
Editor
Toronto -
Jeremy Garchow
December 2, 2009 at 10:09 pm[Matt Lyon] “I didn’t think compressor could do proper AA/BB/BC/CD/DD style field ordering. But some of these posts seem to suggest it can?”
Yes, it can.
https://forums.creativecow.net/readpost/8/1056076
Jeremy
Matt Lyon
December 2, 2009 at 10:17 pmGreat! Thanks Jeremy… works like a charm.
Matt Lyon
Editor
Toronto
