Activity Forums Boris FX How to export tga file with alpha?
  • How to export tga file with alpha?
    Posted by Charlie Chang on January 28, 2006 at 5:02 pm
    I’m in Boris Red and trying to export a vector text out of Red as a tga file. I can’t figure how to export so that there is no background. Is there a way to export as a tga file with a transparent background? How do I add alpha channel when exporting?
    Mark replied 20 years, 7 months ago 2 Members · 4 Replies
  • Mark
    January 29, 2006 at 12:24 am
    If you turn all tracks off, except for the graphic that has the alpha info (tranparency), you should see the checkered background. Do file-export-TGA and the alpha is automatically attached. I do this often with titles.
    Mark
  • Mark
    January 29, 2006 at 12:25 am
    PS….if you are bringing the graphic in from an NLE into Boris, you will not see the alpha, as all of the NLEs that I have used do not pass along the alpha info to Boris, so you would have to import the graphic into Boris from your hard drive.
  • Charlie Chang
    January 29, 2006 at 2:58 am
    Thank you so much. That works wonderfuly.
  • Mark
    January 29, 2006 at 11:26 am
    my pleasure.
    mark
