Activity › Forums › Adobe Photoshop › how to export round picture…
Posted by Tomer on January 21, 2006 at 12:13 pmand if i can use the crop tool in round lines,
thank you.Troy E. parker replied 20 years, 8 months ago 2 Members · 1 Reply -
1 Reply
Troy E. parker
January 22, 2006 at 2:58 pmGood question!
If I understand this correctly, you want to export an image that is formatted to be round… due to the reality of square pixels (rectangular for video) this is not possible, but we can work around this.
We will need to know what you end use is for the best answer (try to help us with a bit more info on output etc), but in general for a screen displayed image (web/video etc) you will want to export the image with a transparent background using a round clipping path, mask or similar tech to hold back any color outside the round shape. (searcnh this forum or google for more info)
If you are going to print and the area outside the round shape is to be white, (with no other elements on the final work), you can simply use a white background outside the round shape.
