Activity › Forums › Apple Final Cut Pro Legacy › How to export in exact same format as original material
  • How to export in exact same format as original material
    Posted by Andrew Ward on February 11, 2012 at 5:41 pm
    I have a clip ripped from blu-ray into Mp4… I edited it and want to now save it back out to the exact same format (which I want to play on my Ipad).
    I don’t see any export formats which look automatically the same… How do I say “Just export the thing in the SAME format!”
    I’m using Final Cut Pro 5 (sorry… can’t afford the pricey upgrades)
    Here are the details of the clip: (Bold items are what I want to maintain going forward.) And I ESPECIALLY don’t want a distorted aspect-ratio. I HATE HATE HATE distorted aspect ratios!!!
    Format : MPEG-4
    Codec ID : M4V
    File size : 2.02 GiB
    Duration : 1h 39mn
    Overall bit rate mode : Variable
    Overall bit rate : 2 918 Kbps
    Movie name : title00001
    Writing application : DigiArty AV Encoder Core
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Baseline@L3.0
    Format settings, CABAC : No
    Format settings, ReFrames : 6 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 1h 39mn
    Bit rate : 2 785 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.101
    Stream size : 1.93 GiB (95%)
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 1h 39mn
    Bit rate mode : Variable
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 90.9 MiB (4%)
    MANY thanks for your advice!!!
    Thank You
    -Andrew
    John Pale replied 14 years, 7 months ago 2 Members · 1 Reply
  • John Pale
    February 11, 2012 at 6:13 pm
    You can’t do it directly. The format used by the iPad is not a valid editing format in FCP (well, it sort of is in FCPX). What Easy Setup did you use in FCP for your ripped file? That is the format your movie now is (I’m guessing you got a red line over your timeline and had to render).
    You said you don’t want to upgrade to a version of FCP that existed after the iPad was introduced either, so here is the best you can do.
    Export a Quicktime Movie (not Quicktime Conversion). This is the same as your timeline settings, whatever they may be. This can be a reference movie (uncheck self contained), or self contained.
    You said you have FCP 5, so I don’t think you will have the iPad preset in your version of Compressor…so download the free program called Handbrake.
    Open your reference movie in Handbrake and select the iPad 2 export preset.
    Do your export. Done…without spending any money, engaging caps lock or using multiple exclamation points.
