Activity › Forums › Adobe After Effects › How to export Hi Rez Jpg in After Effects???
Posted by Tiff Mcginnis on February 28, 2011 at 7:41 amHello!
I am an audio/ visual artist using Flash & After Effects. I need to export an image sequence of my latest work in Hi Resolution asap!! But every time I do it, It exports at 72 dpi… I’ve looked around in preferences and export settings, but can find anything?? Is there a secret magic button somewhere I can hit 300 dpi?? Please help me!! Thanks!
Tiff McGinnis
Darby Edelen replied 15 years, 6 months ago 4 Members · 6 Replies -
Tiff Mcginnis
February 28, 2011 at 3:40 pmI did blow it up to around 3000 by 2500.. they are vector animations i do in flash, so changing the size doesn’t seem to effect the quality in AE4.. but when i saved frame as & then opened it in photo shop… it was 72dpi … i changed it to 300dpi, but when i blew it up to 100%, it was very poor blurry resolution.. and i need screen grabs of my video work to be printed in a book… know any software that will take a hi rez screen grab??
Thanx Dave!!
tiff mcginnis
https://www.vimeo.com/crazygirltv
Michael Szalapski
February 28, 2011 at 4:32 pmLet me make sure we’re understanding you:
You made your AE composition 3000×2500 pixels (and in AE everything looked fine at 100%), saved a frame of it, imported that still frame into Photoshop, changed the resolution to 300 pixels per inch (which would result in a 10″ x 8.333″ document), and it looked bad?– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Tiff Mcginnis
February 28, 2011 at 4:45 pmI meant AE CS4 … I do rasterize.. i dont use open GL… not using multiprocessing…
Tiff Mcginnis
February 28, 2011 at 4:50 pmto be honest, i wasnt blowing it up in AE at 100% oops.. just looked and it’s kinda ruff.. ill go back in flash re-export at 3000 by 2000… then reimport in AE CS4 at the same size and see if it makes a diff… oops! thanx!
Rob Erobs
February 28, 2011 at 5:37 pmI’m working on a similar project, I tried exporting using save frame as and got the same result as you. Then I tried this which worked:
1) shorten work area to one frame
2) export using make movie
3) change output format to photoshop sequence with no compression
4) in photoshop change the resolution to 300 dpi -
Darby Edelen
February 28, 2011 at 7:34 pm[Tiff McGinnis] “i changed it to 300dpi, but when i blew it up to 100%, it was very poor blurry resolution..”
Make sure you do not have “Resample Image” enabled when you use Image Size in Photoshop.
Darby Edelen
