Activity › Forums › Compression Techniques › How to export HD 16:9?
  • How to export HD 16:9?
    Posted by Alan on August 18, 2005 at 9:13 pm
    Can anybody give me the steps on how to export a Final Cut uncompressed HD project as an email-friendly mpeg4 file preserving the 16:9 aspect ratio. I can’t figure out how to do this without getting the dreaded squished look!
    Alan replied 21 years, 1 month ago 2 Members · 2 Replies
  • Charles Simonson
    August 19, 2005 at 3:00 am
    I assume you want to use FCP to do a direct export. From FCP, go to File>Export>Using Quicktime Conversion… Then select the Options button, choose the MPEG-4 codec from the settings button, and then set a 16:9 custom size from the size button. Can’t see any reason why this wouldn’t work.
  • Alan
    August 19, 2005 at 12:03 pm
    It seems simple enough. I’ll try it. Will Compressor give me better results?
