Activity › Forums › Adobe Premiere Pro › How to export for Digital Cinema Package DCP
Posted by Drew Keo on March 13, 2013 at 7:17 pmHi –
I’ve found previous posts asking this question, but couldn’t find any responses in the Premiere Pro forum. I am working with CS5 and need to export a file to be put on DCP for screening. Is it possible? What settings do I use?
Bill Simonett replied 11 years, 6 months ago 12 Members · 11 Replies -
Angelo Lorenzo
March 13, 2013 at 7:26 pmNo. DCP creation is a very involved process and if you don’t have the ability to test DCP you’ve created before distribution then I strongly suggest you have a mastering house perform the conversion.
https://dannylaceyfilm.blogspot.com/2012/06/getting-to-grips-with-making-digital.html is a good starting point.
Please be aware that you have to split any stereo content to at least LRC(left front, right front, center) mix. If you already have a 5.1 or 7.1 mix, you should be fine. DCP does not support mono or stereo sources.
Premiere and After Effects can both export TIFF. If I recall correctly, OpenDCP should do the color conversion to XYZ color space.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Stephen Smith
March 13, 2013 at 7:26 pmIt is not possible in Premiere. Sounds like a great thing to make a request for, I have and you should to.
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
I currently have another company do DCP files for me. They have a 2K projector so they can check there work when they are done. They do a great job, here is there site: https://universalpost.tv/ Best of luck.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Vimeo page
Tadeusz Kleczek
March 14, 2013 at 6:26 am[Stephen Smith] “It is not possible in Premiere. Sounds like a great thing to make a request for, I have and you should to.”
It,s not true. It is POSSIBLE in Premiere Pro but You need plugin Rovio Total Code:
The plug-in suite works seamlessly with Adobe Premiere Pro to support:
AVC-Intra, DVCPRO, VC-3, Ikegami GFCAM, JPEG2000 and MXF OP-1a
MPEG, DVCPRO and AVC-Intra smart rendering for faster exporting of those formats
H.264/AVC GPU-accelerated encoding
Dolby Digital 5.1 surround sound for DVD and Blu-ray® Disc
DCI-compliant JPEG2000 Digital Cinema PackagesIt, easy and working! But…..plugin cost is 999$
Teddy
Tero Ahlfors
March 14, 2013 at 6:35 amYou can then make a DCP with the free OpenDCP https://opendcp.org/
Drew Lahat
March 14, 2013 at 7:03 pmAfter saying out loud that there is no real, reliable easy to use DCP creation solution, I had my mouth shut yesterday on CML. Check this out:
https://www.magnamana.com/products/finaldcp/
$650, and there’s a fully-functional free version with a watermark (one that you might be able to project with, not the super-obstructive kind we’re used to with plug-ins).
Axel Mertes
March 16, 2013 at 4:42 pmYep,
our FinalDCP is designed to be very streamlined for the average user.
At best you export a Quicktime or AVI file (most codecs like CineForm, DNxHD, ProRes, BMD, AJA etc. are supported) and import into FinalDCP.Regarding speed:
We have a new professional version of the RenderNode coming, being 4 times faster. That means a single machine can do realtime. On our RenderFarm we tests about 40fps in 4K, 130+ fps in 2K and we are not yet done.
Cheers,
Axel -
Jith Paul
March 20, 2013 at 4:42 pmHere’s a quick guide I put together with lessons learned creating my first DCP with the Adobe suite and Open DCP. https://dcp.treepotmedia.com
Carl Hetherington
May 3, 2013 at 10:45 amAlthough not supporting direct export from CS5, DVD-o-matic might be useful:
https://carlh.net/software/dvdomatic
It is badly named (at the moment!) but it will take a video file (in more-or-less any format) and turn it into a DCP. It is free and open-source. Feel free to email me with any queries (cth@carlh.net)
Best
Carl
Simon Faris
August 18, 2013 at 6:03 pmHi All,
The resurrection of a thread here. I have a request from an associate to see if I can convert an encrypted DCP file into a NON encrypted DCP file.I am using a Windows 7pro 64bit 16gb of ram. Nvidia q4000 card I do not have a projector to test it on. I was hoping to be able to re-render it, if possible in Adobe’s Cs6?
This short file (996mb) was sent to me via a version of Dropbox, yet the info in the links state I need or should place the files on a drive…Is that an absolute, or can I just export the file and resend via drop box without placing it on a drive? With out any ‘hitches’ on the other end?There are a couple of links above that appear to be an answer for creating DCP from files. I am merely trying to recode a current DCP file from encrypted to Non encrypted. Any ideas on this, or new swifter ways to achieve this? This thread was made months ago…
Thank you
SFS.Faris
https://www.NetCommercial.Net -
Dorian Neyra
August 8, 2014 at 2:45 amthe newest update of Premiere Creative Cloud allows you to export directly as 2k DCP.
