Activity › Forums › Apple Final Cut Pro Legacy › How to export each audio clip separately?
  • How to export each audio clip separately?
    Posted by Martijn Calkhoven on July 13, 2009 at 3:13 pm
    My English isn’t too brilliant, so please bear with me.
    I have this audio track placed in a sequence. This track contains voice acting. Because the actor exported the whole script in one track, I have to cut it up. And since I have nothing else to do that with, I’m using FCP. I just finished cutting everything up nicely, deleting noises and silences and removing all the gaps so that all the remaining clips are stuck together. Here’s where my problem starts: I thought it was possible to export all those clips individually to wave files, but unfortunately I’m unable to find an export method to do this! Did I just miss it or am I doing something wrong?
    I hope someone can help me out here!
    Kind regards,
    Martijn
    Martijn Calkhoven replied 17 years, 2 months ago 3 Members · 4 Replies
  • Stace Carter
    July 13, 2009 at 5:17 pm
    I’m just guessing here, but can you:
    -Drag the Sequence clips from the sequence to a new bin
    -Open that bin, select all, File-> Batch Export?
    Cheers,
    S
    Apple Certified Trainer, Final Cut Pro Level I
    Final Cut Studio Master Pro
  • Alan Okey
    July 13, 2009 at 6:04 pm
    Try double-clicking on a clip in the timeline, selecting the viewer window, then export the audio clip. This should export only the selected clip, not the whole timeline track.
  • Martijn Calkhoven
    July 13, 2009 at 7:05 pm
    Thank you for the quick response!
    I just found the same solution Alan was talking about, but it really takes a lot of time, I’m talking about 40+ clips 🙁
    But Stace’s idea was exactly what I was looking for! I can now rename every track in the bin.(though I think this will probably be possible with clips too)
    Thank you so much! My school’s closed ’till september, so I couldn’t ask a teacher and I really need to get this done! This website is great!
    Again, thank you both!
    Martijn
  • Martijn Calkhoven
    July 14, 2009 at 2:13 pm
    All was going well, but now I’ve stumbled upon a new problem!
    For some reason, all of the audio files exported using Stace’s method suffer from a serious stutter. Every half second is followed by a short silence! What am I doing wrong?
