Activity › Forums › Adobe After Effects › How to export AVIs w/alphas?
  • How to export AVIs w/alphas?
    Posted by Javierdl on February 11, 2006 at 6:34 am
    It’s been so long since I did these things I can’t recall now and I could certainly use some memory refreshing
    Ok, this is what I’ve done, have a look and let me know what I’m missing:
    1. Imported a QuickTime file with a green screen already set.
    2. Applyied Color Key Effect, and keyed out its green screen (which worked just fine).
    3. Made sure of having these settings:
    Channel: RGB+Alpha
    Depth: Millions of Color+
    Color: Straight (Unmatted)
    4. exported to avi
    On my 2nd attempt:
    1. Went back to same project and added “Set Matte”, without changing anything in the configuration.
    Should I leave the Set Matte effect there?
    This is how my effects list looks like:
    https://www.javierdl.com/temp/ae_effects.gif
    After each try, I would go back and import the created avi, put it in the timeline, and then put a still image under to confirm that the alpha was working.
    Needless to say nothing has worked.
    Can someone please enlighten me and tell me what am I doing wrong?
    Thanks in advance,
    JDL
    Alexxx replied 20 years, 7 months ago 2 Members · 1 Reply
  • Alexxx
    February 13, 2006 at 3:14 am
    Does it HAVE to be .avi? Generally the most common format for exporting high quality footage WITH alpha is Quicktime-Animation. A lot of people use this a it’s compressed lossless and allows for an alpha channel all in the one file.
    Just do your green-screen keying and then render to Quicktime, Million Colors+ and RGB+ALPHA and make sure you select the ANIMATION codec.
    Now bring that back in and see. You should have the alpha all intact from the previous key-job.
    Alex
    http://www.lightdrop.com.au
