Activity Forums Apple Final Cut Pro Legacy how to export at less file size but full quality
  • how to export at less file size but full quality
    Posted by Rajarshi Banerjee on May 12, 2009 at 11:28 am
    hi everybody,
    i m using FCP installed in imac i.e. no capture card is installed in the machine, now toady i exported a 2 min 10 sec movie with sound in .mov format which size 469 mb. Now i can’t figure out how a 2 min mov can make so much file size. my format is DV Pal
    detail of easy setup
    format; Pal
    use: DV-Pal
    sequence preset: DV PAL48 kHz
    Capture Preset: DV PAL 48 kHz
    Device Control Preset: FireWire Pal
    Playback Output Video: Apple FireWire PAL (720×576)
    Playback Output Audio: FireWire Dv
    Edit to Tape/PTV Output Video: Same as Playback
    Edit to Tape/PTV Output Audio: Same as Playback
    need help
    Rajarshi Banerjee replied 17 years, 3 months ago 3 Members · 4 Replies
  • Walter Biscardi
    May 12, 2009 at 11:45 am
    The file size sounds about right if you exported full DV PAL format. There’s no such thing as “less file size but full quality.”
    If you want to compress the file, you will start to lose quality. What do you need to to with the finished movie file?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Rajarshi Banerjee
    May 13, 2009 at 1:54 pm
    Hi Walter Biscardi, Jr.
    first of all thanku for replying, now about ur Q, i main purpose is to upload it to our company website “https://www.edterra.com” so that our client can watch it. i want to figure the file size and quality balance setting so that in the frame size of 320/240 it must not loose its quality and also streaming must not be stress full job oh i forgot to mention that the .mov film will be converted to flash video.
    am i asking too much……….
  • John Fishback
    May 13, 2009 at 10:12 pm
    What you want to do is use your exported DV movie as the source to encode your Flash (flv) movie. Use an encoder that can use the On2VP6 codec. And, use 2-pass encoding. That will give you the best result. Choose the highest data rate viewers of your site can handle. You can also export a reference movie (do not check “make self-contained) which will be smaller in size than your self-contained DV movie.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24” TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Rajarshi Banerjee
    May 17, 2009 at 10:04 am
    Respected
    John Fishback
    thanku so much for your kind attempt to solve my problem, ur given solution really helped me.
    thank u again
    regards
    raj
