Activity Forums Apple Final Cut Pro Legacy how to export a good looking still picture
  • how to export a good looking still picture
    Posted by Cade Muhlig on January 8, 2007 at 9:26 pm
    im working in hdv, and i wondering if there was any way to export decent still picture. quicktime conversion doesnt fix the interlaced look, and since im working in hdv, the aspect ratio gets stretched to 4:3
    Rafael Amador replied 19 years, 8 months ago 3 Members · 3 Replies
  • Thaxter Clavemarlton
    January 8, 2007 at 9:39 pm
    “Deinterlace” it in Photoshop (in Video Filters).
    And change its aspect to a 16 by 9 ratio.
  • Cade Muhlig
    January 8, 2007 at 11:31 pm
    what if the video was moving, and it blend the fields? any way to fix that? its not blurry, i think ill just have to find a long way to do it such as from tape deck through my monitor to kona lh. or something like that because my monitor displays it perfectly.
    thanks for the tip though
  • Rafael Amador
    January 9, 2007 at 4:04 am
    That the reason you must de-interlace to clean the blending. The de-interlacer of Photoshop is not the best one. You better do it in FC, AE or Shake.
    The change in the aspect ratio is normal because your watching with an application that do not interpret aspect ratios. Is just a matter of displaying the picture, because you still having the same number of pixels. If you bring your still to FC, Shake or AE and you set the correct pixels-aspect will look weel in your monitor. In Photoshop or QT they will look defformed.
    Salud,
    Rafael
