Activity › Forums › DaVinci Resolve › How to export a 25 fps project as 25 fps?
Posted by Spazz Nielsen on January 8, 2012 at 9:47 amI’m testing out Davinci Resolve lite and wonder why my 25 fps XML imported FCP project only can be rendered out as 23.98 or 24 fps? Is there export support for other frame rates than this?
Robert Houllahan replied 14 years, 8 months ago 2 Members · 5 Replies -
Robert Houllahan
January 8, 2012 at 7:37 pmI have exported 25fps projects as 25fps You have to have the settings set right for 25fps. Se the playback framerate and the timecode options both to 25fps in the setup screen and you will be able to render out 25fps.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
Spazz Nielsen
January 9, 2012 at 12:20 amThe timecode option is set to 24 and the field is grayed out. I’m in the lite version, guess this might be a limitation to the lite version?
Robert Houllahan
January 9, 2012 at 1:34 amYOu have to set this before you load a edl or create a timeline, you might have to make a new project to get it to work.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
Spazz Nielsen
January 9, 2012 at 7:40 pmThank you. When setting up the timeline to be 25 fps from the start I can also render out as 25 fps.
Robert Houllahan
January 9, 2012 at 8:02 pmyes
Robert Houllahan
Director / Colorist
Cinelab Inc.
