Activity › Forums › Adobe Premiere Pro › how to export 4096×4096 VR with moderate bitrate?
  • how to export 4096×4096 VR with moderate bitrate?
    Posted by Steve Bransford on June 7, 2018 at 2:27 pm
    I have a 4096×4096 59.94fps VR Over-Under sequence in Premiere that I’m trying to export to play in the new Lenovo Mirage Solo standalone VR headset. The Mirage can handle up to 4096×4096 resolution, so I’d like to export at that resolution to maintain the highest quality. The problem is that there are frame size restrictions for exporting H.264 (the highest resolution Premiere/Media Encoder allows me is 2304×2304). HEVC H.265 allows for higher frame sizes, but the Mirage can’t seem to play back H.265 VR even at relatively low bitrates. I tried doing Quicktime exports via ProRes proxy but got files with huge data rates that couldn’t be played in the Mirage. Any recommendations for how to export (not in HEVC) a 4096×4096 59.94fps VR Over-Under sequence that can result in a moderate bitrate (maybe in the 20Mbps range)? Is there a way to export a Quicktime MP4 file that isn’t encoded with H.264? Thanks for any help folks can provide.
    Mike Sevigny replied 8 years, 3 months ago 2 Members · 4 Replies
  • Mike Sevigny
    June 14, 2018 at 7:43 pm
    Hey Steve,
    are you on mac or pc?
    Mike Sevigny
    https://www.torusmedialabs.com
  • Steve Bransford
    June 18, 2018 at 7:20 pm
    I’m on a Mac. If you think I can do what I want to do on a PC, I’d love to know how. Thanks.
  • Mike Sevigny
    June 19, 2018 at 10:57 am
    Encoding H.264s at a resolution of 4096×4096 on PC/Windows
    Step #1
    Export your video in a highres codec. On macOS you can make an Apple Prores and on PC I would recommend an image sequence like PNG or JPG (depending on the quality of the original image). Export the audio as a separate file if you’re using an image sequence.
    Step #2
    On the PC side, download the latest version of VirtualDub 2 and launch the application. It comes with a couple of executables in the zip file, use VirtualDub64.exe if you’re on Windows 64bit.
    VirtualDub is a free video processing utility for Windows
    Download Link: https://sourceforge.net/projects/vdfiltermod/files/VirtualDub%20pack/version%2019/
    Step #3
    Open the media in VirtualDub by clicking on File > Open video file..
    Note: If you did not render an image sequence in Step #1, skip to Step #6
    Step #4
    Adjust the framerate by clicking on Video > Frame Rate. By default the FPS is set to 10 for image sequences. This default value can be changed in the preferences so you don’t have to change it every time.
    Step #5
    You will need to insert the audio by clicking on Audio > Audio from other file… and selecting the audio file you exported in Step #1.
    Step #6
    A) Click on File > Save as…
    In the ‘Save as’ pop-up select ‘.mp4’ from the ‘Save as type’ dropdown menu and then click on the ‘Change’ button.
    B) In the pop-up window, select ‘x264 8bit – H.264/MPEG-4 AVC codec’ and click on ‘Configure’ to configure the h264 compression
    C) In the new pop-up window under ‘Rate Control’, select ‘Single pass – bitrate based (ABR)’ and set the average bitrate as desired.
    Step #7
    Click ‘OK’ on both windows. Change the audio settings to what you need and click the ‘Save’ button
    Check your final output for artifacting and tweak the output settings as you see fit.
    Hope this helps.
    Mike Sevigny
    CTO – Torus Media Labs
  • Mike Sevigny
    June 22, 2018 at 5:39 pm
    Even better, here’s a great video by CreatorUp
    https://www.youtube.com/watch?v=8qz8WFfZTKM
