Activity Forums Adobe After Effects How to explode text into characters, then convert each generated layer to shape using script
  • How to explode text into characters, then convert each generated layer to shape using script
    Posted by Noelia Sanchez on May 29, 2019 at 1:00 pm
    Hello,
    I am not very good when it comes to scripting, so I came here to ask for help.
    What I try to achieve is exactly what the title says: to explode text into characters (on separate layers), then create a shape from each generated text layer using a script – basically, select the text layer and run a script that does this.
    I know that this command creates shapes from a text layer: app.executeCommand(app.findMenuCommandId("Create Shapes from Text"));
    but I can’t make it work with multiple selected layers… it only works if I select each layer separately.
    Also, I don’t know how to explode the text into characters.
    Maybe someone could help me.
    Thank you in advance!
    Mark Whitney replied 7 years, 3 months ago 3 Members · 4 Replies
  • Oleg Pirogov
    May 29, 2019 at 2:40 pm
    Quick question: why not the other way around? Converting single text layer to shapes will get you a shape layer with neat sub-layers for each character which you can transfer to separate layers, if you wish.
  • Noelia Sanchez
    May 29, 2019 at 6:37 pm
    Because I need each letter of the text on a separate layer in order to animate it… and it will be a lot of text
  • Noelia Sanchez
    May 29, 2019 at 6:38 pm
    And I also don’t know an automated way to separate the shape sublayers from the single shape layer that will be generated
  • Mark Whitney
    May 31, 2019 at 3:33 pm
    Perhaps your wishing to script your own, but have you check out this from Mamoworld?
    https://aescripts.com/textexploder/
