Activity Forums Adobe Premiere Pro how to expand source sequence from ‘multicam mode’ sequence to make minor edit?
  • how to expand source sequence from ‘multicam mode’ sequence to make minor edit?
    Posted by Wolf Lawrence on August 6, 2014 at 5:51 pm
    hi! I shot a belly dance show. I synchronized picture to audio old school by ear before I realized premiere pro cc can do it automatically.
    Because I already had it all synchronized, I felt forced to skip the multicam textbook source/target setup steps that include ‘synch’ and instead selected the relevant AV tracks in timeline and nested them to enable multicam so my multicam sequence does not bear a multicam icon. Still, it enabled me to multi-cam edit the whole show switching on the fly like a charm. (Q1: Is there a difference between the two types of multicam sequences or are they essentially the same?)
    At the last second, I realized one source sequence in the middle was matched to an off beat so I needed to go into the source and shift the audio track. (Q2: How do I do that?)
    I read that I press Ctrl+Shift+F where you want to open the source sequence in the Timeline panel. This did open a separate set of expanded tracks as expected so I made the quick edit and saved changes. I thought I was done, but when I play back my multicam sequence, even after closing/opening Pr I do not see those changes.
    Q3 What am I doing wrong? Is it a bug? Are the sequences unrelated?
    Wolf Lawrence replied 12 years ago 2 Members · 4 Replies
  • Vince Becquiot
    August 6, 2014 at 6:58 pm
    From memory, I hold command (Mac) or Control (PC) and double click on any clip in that sequence.
    That should open the original multicam sequence.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Wolf Lawrence
    August 6, 2014 at 7:42 pm
    it does expand and I made the edit and verified it sounds great. but how do I get the edit to show up in multicam collapsed sequence after saving? it wont do it.
  • Vince Becquiot
    August 6, 2014 at 10:18 pm
    Whatever you edit in your original sequence should show up if the collapsed version right away.
    Vince Becquiot
  • Wolf Lawrence
    August 7, 2014 at 4:36 am
    the song tracks I laid in separately are the culprit, the ‘non-camera audio’ that did not get included in the ‘nest’. all solved thanks.
